G'day to all from down under ....:grin2:
I have a 017 SDGT and I fitted the 40tooth rear sprocket from Supersprox.
It went on in less than 15-20mins (that quick change system is errrrr very quick :wink2
Big however is that you/whoever, might have installed the sprocket incorrectly...... I lost my pics when my Laptop got sick..... sorry..... but the guts is - put the pretty side to the inside..... and look down the chain when installed to confirm F-R sprockets are in line....... inspect the oem 38t sprocket and you will see the wear marks from the hub & the bolts........ I almost fell for the pretty side out error until I double checked the marks on the original.
By the way..... I didn't need a longer chain.... I adjusted the rear axle all the way in, put the chain on the sprocket before placing on the hub, tightened the bolts, then reset the chain slack to the book setting. I had done about 5000kms before I was able to buy a 40T, maybe that helped....
Also...... be warned...... fitting a 16t front sprocket is not the way to go unless you want to pull wheelies all the time (a 16t front = a 43t rear..... as the GT is only slightly over geared it only needs +1 or +2 teeth on the rear - or 1/2 a tooth on the front....:grin2:..... which is not possible). The rear sprocket is the easiest and cheapest to change anyway and a 40t rear will bring 6th gear back into play for 110kph speed zones with an increase of 200-250rpms in 5th for 100kph....... it won't rev it's head off and actually makes the GT smoother by keeping the motor in the engine's sweet spot.
Do it...... it works....... a 39t rear would suit guys who have minimal low speed traffic zones and more highway work (approx +180rpm @100kph in 5th)...... the standard 17/38 is best suited to Autostrada's in Europe with unlimited (?) speed zones......:clap:
Wish I still had those pics....... they are posted on the other forum... KTM Super Twins.... 0
Ahaa...... I can do this........ here they are.......
