2008 KTM 530 EXC Won't Start
18K views 16 replies 5 participants last post by  cors187
More of the same problem
I think it may be a good idea to have another look at your valve clearance and compression. I was not convinced tightening valve clearances was a good idea, but I don’t have all the answers either. It just didn’t make sense to me.
I would start with basic testing and assume your original problem remains. Your motor started well and ran well for a time. Test compression first. Then recheck valve clearances. Let’s hope you find something simple and easy. Good luck
Just to add to the confusion
Sorry for the confusion here but I’m trying to understand here. I looked for previous posts from your recent troubles with hard cranking. I wanted to make sure our terminology is correct and we have our facts straight. Just to get us speaking the same language. Your motor cranks but will not run now except for a sputter or pop. Your previous troubles were resolved and your motor ran after you tightened valve clearances? Or did it simply crank better but not run after the recent valve adjustment?
