690 endruo r rims on the 690 smc?
9.8K views 13 replies 3 participants last post by  Adam Fischer
Hello. I was wondering if the ktm 690 enduro r rims w/ tyres fit on the 690 smc. I want to be able to do some dirt riding with enduro tyres and street riding with the smc tyres.
#6 ·
Welcome to the forum. Where are you located BTW?
Here is the 690 Enduro rear wheel:
690 SMC rear wheel:
#9 ·
SMC rear wheel
(32) 75310085044
75310085144
WHEEL SPINDLE M25X1,5 L=275MM
front wheel spindle axle
(20) 77309081000 WHEEL SPIN.FR. D=26 M24x1,5 07
ENDURO 690
Rear wheel spindle axle
(32) 75310085044
75310085144
(20) 75009081000 WHEEL SPINDLE FRONT D=26MM 07
front wheel spindle is different number but looks same
#10 ·
Axle length and diameters as the same.
IIRC from ADVrider, it's the front brake disk
on the SMC is 320mm diameter, so you need
a caliper swap or relocation bracket because
the enduro front disk is ~200mm diameter.
#12 ·
I think you could do it physically, but from what I've read you may have "too" much front
braking on dirt then.
Would you be using the SMC two piston caliper, or the single enduro caliper?
