141 - 160 of 480 Posts
It's amazing! Sounds awesome, on the loud side though. The map really gives it a lot of extra mid range power. It consumes quite a bit more fuel now, and cruising at low speeds is a bit rough, but really gives it character.
I am able to power wheelie in 4th now fairly easily. Just load the front end a bit by letter of the gas at 8k rpm, when it hits 7k just crack it open and she comes right up... I'm 275lbs too.
I bought a SC slip on for now..........but statements like this...........you are killing me haha........jealous one day I will have that exhaust and uncork this thing! Thanks for all the pictures and write ups it is appreciated!
I wonder if the same map from KTM works for the Austin Racing system? Seems like it should....
Apparently that's exactly what Richard Austin has done with his SDR....no idea how he wangled that, maybe had the Akra fitted initially. It's not like a bit of software you can share around on a USB stick....bike has to be plugged into KTM diagnostic system, and map uploaded from KTM HQ after bike ID and request validity checks.
The map thing is wearing me down. May just get a slip on as well. I'm experiencing KTM ownership
you don't have to worry about the map it works great I have made 4,000 km with the full exchust and the sound smooths out after 3000km :)
I can’t find a dealer that will install the map for me without having to sign a waiver I think to void my warranty. I’m sure the map works great of someone who can get the map.
Has anyone living in Ontario, Canada had the full Akro EVO successfully installed with a map by a dealer anywhere?
That is kinda where I was at..........I have the SC Project S1 slip on and it sounds really good. It comes corked up with a db killer installed and the bike was really quite that way not much more bark than stock. I removed that db insert and it sounds really good.......not obnoxious but way more throaty...........some day I will dive into the full exhaust for the bike, but for now the bike sounds good looks better than the stock suitcase muffler and still has all its manners throughout the rev range.
I got a slip on also Dave, with the db insert in, it was about as loud as the stock muffler, i removed the baffle, much nicer deeper sound. it has a 38mm opening, i filled it out to 42mm, (it had a lip) thats a 20% increase, and it let out marginally more sound. Im happy with where its at now.
Hi, i have a problem with the magic box and i cant resolve!
The only difference between me and @kmanou is that i have the yellow and brown on the 3 pin connector in different position. But i change the position in the relay so i have the gnd and vcc right and the rele is alimented. I fix 6 second.
But the bike don t start! So there are my photos of the connectors on the bike and my magic box. Please help me!
98736
98738
98739
98740
98741
98742
98743
98744
98737
check all the cables for shorting inside the connector with a multimeter becouse if you dont have the proper tool for the pins you must be extra careful when you slide them in the holes also try from the 4 pin connector to put the black cable to the NO and the brown to com and check if it works
