42t rear sprocket
Me wanna get one :yes:
Any suggestions on brands / suppliers ?
I don't believe the service manuals are.Just an FYI, all the manuals are available online from KTM.
Yeah, it's a gamble but it fitted up perfectly and the rivets are tight. Only done about 100k's so far. I'll keep an eye on it and time will tell.Good luck with that. I would not be inclined to buy a cheap chinese imitation of a SuperSprox.
As I read it, it's not slack. It's the gap between chain and bottom of swinging arm, when you lift the bottom run of chain.Chain slack spec in manual seems very small... 5mm / .25" with the bike on a swingarm stand. Is that correct?
Just wanted to post back re: the 46 rear (powerparts supersprox) w/ stock front... LOVE IT! not really missing the top speed losses, gearbox really feels perfect now. It's just always in the right gear. got a rivet link btwrelated question... I got a new rear (46, keeping stock front) and hence a new chain, the chain came with a clip type master link. I know these are considered "ok" for dirt bikes, but is it safe to use on a duke?
thanks.
-Andrew
Chain and sprocketstorque
noun
1.
MECHANICS
a force that tends to cause rotation.
Torque is a measure of how much a force acting on an object causes that object to rotate.
Front Rear Ratio Torque Speed Front Rear Ratio Torque Speed DIFFERENCE
16T 38T 2.38 -5.30% +5.3%
16T 39T 2.44 -2.60% +2.6%
16T 40T 2.5
15T 38T 2.53 +1.3% -1.30%
16T 41T 2.56 +2.4% -2.40%
15T 39T 2.6 +3.8% -3.80%
16T 42T 2.63 +4.8% -4.80%
15T 40T 2.67 +6.3% -6.30%
16T 43T 2.69 +7.0% -7.00%
15T 41T 2.73 +8.5% -8.50%
16T 44T 2.75 +9.1% -9.10%
16T 45T 2.81 +11.1% -11.10% 15T 42T 2.8 +10.7% -10.70% 0.40%
16T 46T 2.88 +13.0% -13.00% 15T 43T 2.87 +12.8% -12.80% 0.20%
16T 47T 2.94 +14.9% -14.90% 15T 44T 2.93 +14.8% -14.80% 0.10%
16T 48T 3 +16.7% -16.70%
17T 38T 2.235294118 -11.84210526 11.84210526 18T 38T 2.111111111 -18.42105263 18.42105263
17T 39T 2.294117647 -8.974358974 8.974358974 18T 39T 2.166666667 -15.38461538 15.38461538
17T 40T 2.352941176 -6.25 6.25 18T 40T 2.222222222 -12.5 12.5
17T 41T 2.411764706 -3.658536585 3.658536585 18T 41T 2.277777778 -9.756097561 9.756097561
17T 42T 2.470588235 -1.19047619 1.19047619 18T 42T 2.333333333 -7.142857143 7.142857143
17T 43T 2.529411765 1.162790698 -1.162790698 18T 43T 2.388888889 -4.651162791 4.651162791
17T 44T 2.588235294 3.409090909 -3.409090909 18T 44T 2.444444444 -2.272727273 2.272727273
17T 45T 2.647058824 5.555555556 -5.555555556 18T 45T 2.5 0 0
17T 46T 2.705882353 7.608695652 -7.608695652 18T 46T 2.555555556 2.173913043 -2.173913043
17T 47T 2.764705882 9.574468085 -9.574468085 18T 47T 2.611111111 4.255319149 -4.255319149
17T 48T 2.823529412 11.45833333 -11.45833333 18T 48T 2.666666667 6.25 -6.25
has anyone done a dyno with various sprocket configurations so we can see an actual torque curve?
and for clarity - does a 16/42 work with the OEM chain?
