42t rear sprocket
Me wanna get one :yes:
Any suggestions on brands / suppliers ?
Gokes , do you mind if we merge your sprocket thread into the bigger sprocket thread?Put the 42 on today, went on fine after flipping the blocks. First ride tomorrow with the new gearing.
Oh very interesting. Just did about 150 miles through mountain twisties and I like it. It's not world chaning, but it just lets you be in the optimal gear more often, and get more power down exiting corners.Going full boldor
The real spec about it, is 10% torque.
It could be the best mod for the 690 power/weight
Front Rear Ratio Torque Speed
15T 38T 2.53 +1.3% -1.3%
15T 39T 2.60 +3.8% -3.8%
15T 40T 2.67 +6.3% -6.3%
15T 41T 2.73 +8.5% -8.5%
15T 42T 2.80 +10.7% -10.7%
15T 43T 2.87 +12.8% -12.8%
15T 44T 2.93 +14.8% -14.8%
16T 38T 2.38 -5.3% +5.3%
16T 39T 2.44 -2.6% +2.6%
16T 40T 2.50
16T 41T 2.56 +2.4% -2.4%
16T 42T 2.63 +4.8% -4.8%
16T 43T 2.69 +7.0% -7.0%
16T 44T 2.75 +9.1% -9.1%
check the spec on 15/44
Sure no worriesGokes , do you mind if we merge your sprocket thread into the bigger sprocket thread?Put the 42 on today, went on fine after flipping the blocks. First ride tomorrow with the new gearing.
will do. ThanksYeah but...I wouldn't. It's a very torquey bike with lots of vibrations. Chances are it will be fine for the life of the chain, but a rivet master link is a few dollars and any moto shop should have them in stock. Worth the peace of mind. You can fit a rivet master link on your chain. Throw the clip on for now (if you can even get it on. I hate those f.ucking things so much) and go get a rivet style.
Never mind, found it. 118 links.What is the length of the stock chain (number of links)?
No, the manual lies to you. Don't believe anything it says. :hang:Chain slack spec in manual seems very small... 5mm / .25" with the bike on a swingarm stand. Is that correct?
