Ok, which Specific led turn signals are used with the install of the akra exhaust
With map, to “fool” the Ecu, need a link
Thx
Thx
Speaking for myself (I installed LEDperf indicators, which also came with those bullet connectors), I spliced the new LED wires into the connectors cut from the factory indicators and installed. You can get adapters, as I recall, but it wasn’t worth it for me.How did you hook the CNCs up? The plugs are totally different from what's on the bike.
Here's the little CNC plugs:
Here's the bike plug:
Did you just snip the connectors and tie it all together? Or do I have the wrong model of Flows?
So you're running the stock OEM LED Euro signals and they work with the akra map?I am running the OEM LED Euro signals - bright af.
Rizoma makes "no-cut" adapters for this situation. They specify this one for the latest Gen 3 Wiring kit for front and rear Rizoma turn signals but I think if you are trying to achieve the "Akra map" fix, you may want to use the ones for the Gen 2How did you hook the CNCs up? The plugs are totally different from what's on the bike.
I just stripped the wiresHow did you hook the CNCs up? The plugs are totally different from what's on the bike.
Good catch! It looks like this would be the one to get. And they say it's compatible with a Gen3:Rizoma makes "no-cut" adapters for this situation. They specify this one for the latest Gen 3 Wiring kit for front and rear Rizoma turn signals but I think if you are trying to achieve the "Akra map" fix, you may want to use the ones for the Gen 2
did you get an answer to this question?So you're running the stock OEM LED Euro signals and they work with the akra map?
No, and it didn’t work for me last year when I bought my ‘21. I have to use the magic box with the euro LEDs. Was just wondered what he was going to say.did you get an answer to this question?
on a 21 no adjustment is required. You install LEDs, no resistors, and it works.If I wasn't doing a Akro map can I just due a full led conversion and have the dealer switch to led mode like my 890r with no issue on a 23 SDR?
I already had Rizoma Corsa's from my 890R installed up front (no resistors) and Motogadget m-blaze pins in the rear (no resistors) on my 23SD. Everything works fine now. Will be getting my full system installed and Akra map flashed soon. Fingers crossed it works out with no need for the magic box.View attachment 117768 View attachment 117768 Around $100 usd a pair if you like the look. CNC Racing sequential leds
